Date:    9-8-2018
Number of Hours:    8.00
Brief Description:    Painting, fitted ailerons, and Delrin spacer mod
Painted the inside and out of the final skin for each wing. Clecoed in place for storage.
Tried various diameter Delrin rod spacers.. the 12mm rod gave 31 degrees of upward travel, well within limits. Autopilot roll servo limiter just beyond the range of movement permitted by the delrin spacer, so all looking good.
Also primed the Grove gear legs...
