Date:    9-6-2018
Number of Hours:    3.00
Brief Description:    Wiring
Modified some of the wiring in the port wing. Took the ground from the stall warner off the wing skin and replaced it with a ground wire that will go to a common ground in the fuselage later.
Routed the heated pitot cable.
