Date:    12-17-2018
Number of Hours:    3.00
Brief Description:    Aspen RSM positioning
Frustrating day... need to install RSM but where?
Last night, I ran a cable through the HS and then started on a mounting plate design without removing wing tip. Wrong decision!
I put some epoxy filler into the tip to reinforce it redy for mount bracket screws, didnt notice it leak inside the rib... where it succesfully bonded the cable to the leading edge!
After a couple of hours trying to burr away the epoxy, I ended up cutting the cable.
Then had an offer to swap the Aspen system for a G3X system.... All up in the air now...
Interior painted this morning!
