11-6-2018 |
2.00 |
Rear rudder pedals finished. |
fixed the rudder cables to the firewall. Then started the rear seat pedal installation. Started with 'remove the two bolts.... what a bugger! Got easier when I removed a bolt from the undercarriage gear nox first, then the two that had to be removed. Install the bracket using the pre-drilled hole, then match drill the second hole.. the problem being that it was impossible to get a pen into the required spot to mark the location, impossible to get in with a drill of any configuration.. so I made a hole marker from an AN3 bolt, cut short and ground down to a point. Slotted into the hole, marked the spot and all ended well! Just got to do the SB side tomorrow. Made the push rods for the pedls, and prepped and primed the mount for the rudder pedals |
