Date:    4-28-2018
Number of Hours:    11.00
Brief Description:    LE tweaks, started elevator prep
A long day, but fruitful!
After going back to the rudder LE, I decided that the middle section could be better, The top and bottom bits were good.Drilling out the rivets proved surprisingly easy, so I bend the LE a bit more and it worked much better. Spent all day filling, sanding, filling, sanding until it looked ok... Sprayed it with rattle can primer as a 'highlighter' and realised that there was a lot more sanding and filling to do!
Got bored after a while, so moved on to prepping the elevator ribs and prepping the skin.
