Date:    4-19-2018
Number of Hours:    3.00
Brief Description:    Rear spar rivetting... real construction!
Rivetted the rear spar, and it felt like real progress!
The outer rivets seemed awfully long at 5/16th, and couldnt keep them straight. The instructions state specifically that ' the rivet lengths called for on the plans are correct, so I persevered. Not happy with the result though, so I emailed Van's.
Eric Rushing responded, and confirmed that at times, the plans are wrong so use own judgement to get the best size!
I guess the old adage 'if it looks wrong, it usually is" applies. 4/16th rivets work just fine!
