9-8-2005 |
3.00 |
Parts Fabrication - Seat Backs |
Continued with seat back construction. I marked the drill patterns on the side angles and drilled with the drill press. I then used the drilled holes for backdrilling into the seatbacks. Next I used the cutoff saw on the hinges. Then I marked the rivet pattern and drilled on the press. |
