Date:    3-10-2005
Number of Hours:    3.00
Brief Description:    Drilled right HS-405 ribs and nose ribs to spar
Plans were sketchy here. I lined the nose rib up with the skin and used that as a reference to drill the HS-405 rib to the spar and HS-710 and 714 angles. It turned out pretty good.
