1-31-2006 |
3.00 |
Began fuel system installation |
Started fuel system installation. Glued rubber strips onto airframe behind tanks. Drilled holes for fuel level transducer. Reviewed all electrical schematics and crossreferenced wire connections to the harnesses. Traced wires in harness for oil pressure sender. Will use ACIS fuse in overhead for the lighting circuits. |
