Date:    1-3-2006
Number of Hours:    1.50
Brief Description:    Chain Oil Bath
Final installed the bottom of the chain oil bath. Retensioned the main drive belts as had to remove front bolt from the upper engine mount for access to chain oil bath front bolt. Also installed safety wire on the main sprocket to hub bolts.
