10-22-2005 |
3.00 |
Tail rotor |
Drilled hole in tail rotor pulley. Cut and trimmed spacers for tail rotor shaft. Finished assembling all of tail rotor assembly. Trimmed slider linkage for clearance. After discussion with Tom at Rotorway, removed all washers from under the head of bolts onwhich I can tighten from nut end unless washer was needed for spacing.l |
