Date:    7-26-2008
Number of Hours:    2.00
Brief Description:    Drilled pitchhorn alignment bolt holes
Drilled holes for pitch horn AN3 bolts and cut off lower strap to the 5.5 degree point. Need to reattach blades and measure for 7.25 degree point. Also trial fit the new 24AGX battery and fabricated wood spacers for the front and back as the battery is aprox 1.75" shorter than the 35 battery. Also weights 3.5 lbs less!
