Date:    2-15-2008
Number of Hours:    2.50
Brief Description:    Installed the main belly pan
Final installed the main belly pan. Measured for the cyclic boots I will make. Installed the transponder antenna. Final installed the static line tubing. Installed the position lights and the fuel drain valve.
