10-5-2006 |
6.00 |
Door strike plates |
Fabricated the six door strike plates out of .05" aluminum. Installed the bottom ones with rivets. The top and rear ones will screw into nut plates. Installed the upper nut plates in the liner material. Will install the rear ones later. Trimmed the belly pan around the door frame. |
