Date:    8-13-2014
Number of Hours:    3.00
Brief Description:    Baggage door
Received the baggage door lock from Aircraft Spruce and along with it came the two door locks and the ignition switch all keyed to a single key. Installed the baggage door lock and insulation into the interior of the door. Installed the inner closeout panel on the door. Installed the hinge frame onto the fwd portion of the baggage door opening. Centered the baggage door into the hole in the fuselage, drilled the hinge and installed the baggage door into place. Will adjust the striker plate once I have baggage door seal channel.
