Date:    2-17-2014
Number of Hours:    1.50
Brief Description:    Forward bulkhead
Attached the control column mount to the forward fuselage bulkhead and #12 match drilled holes to support control mount. Removed and deburred holes. Removed one bolt at a time from the bulkhead side channel, outbd and inbd fwd seat rail supports and #12 match drilled the holes, replacing bolt after each hole drilled.
