Date:    2-27-2016
Number of Hours:    4.00
Brief Description:    Plane removal from workshop
I need to remove this project from my upper floor workshop down to the lower floor. To do this I am building a palette out of 4 4x4s held together with crossing 2 x 4s. The palette rests aft under the main spar and fwd I will build supports from the palette up to the lower engine mount. I plan to strap the main spar to the aft palette and the engine mount to the more fwd palette. I will have my farmer friend Bob Groulx use his fork lift to lift the palette and plane out of the workshop and down to the lower level.
