Date:    9-29-2015
Number of Hours:    7.00
Brief Description:    Routing harnesses and wires
The passenger headset jack harnesses were too long and would have required me to coil them up and store them somewhere. Rather than take up space and unneeded weight, I elected to shorten those harnesses and route them along the tunnel to the arm rest console. Also I needed to create a second access point for the harnesses to exit the tunnel and come up into the arm rest console. I did this the same way I did the forward access hole the allows the harnesses to pass into the tunnel. Also I attached the fuel flow wire to the red cube which lies in the fwd tunnel.
