2-24-2016 |
5.00 |
Headset harnesses |
The headset harnesses, ADSB coaxial and the flap motor wires run from the panel back through the tunnel. They need to be secured away from the elevator cables. I used Adele clamps to secure the harnesses, coax and wires onto the left side of the tunnel. Wire ties were used to secure loose parts so they would not rub against the elevator cables. |
