Date:    1-29-2016
Number of Hours:    15.00
Brief Description:    Wiring and plumbing
Installed the CHT probes into the cylinder heads. Routed the wires for the CHT and EGT probes along the engine mount and to their appropriate cylinders. Trimmed the wire, placed ring terminals onto wires and then connected them the the CHT and EGT probes. Ran wires from alternator and to starter on the right and left side respectively. Began to run the fuel and oil lines to their respective fixtures. Placed the oil cooler into place. Began to tidy up the wires underneath the panel using string ties to bundle wires to each other.
