12-3-2015 |
5.00 |
Cowl |
The most fwd and outbd edges of the upper and lower cowl did not match. Therefore I built up the shy surface with cloth and then faired in with resin/epoxy. The cowl segments match perfectly now. The slot in the side is for the pin that slides into the hinge holding the upper and lower cowl in place. |
