3-2-2013 |
4.00 |
Vent Lines and Out Board Cap.Sending Plate |
Installed the out-board Capasitive Sender Plates, modified snap bushings internal tank wire run. Installed vent lines in both tanks & started running wire to the in-board sender plate. Realized I can't go much further until I get a "real" torque wrench. I'd like to get the AN fitting bulkhead nuts sealed & torqued down before installing the inboard rib. It's hard to pallet buying a $200.00 torque wrench... Oh well, it will be handy when it comes to FWF / engine work. I'll order it tomorrow. |
