12-2-2012 |
4.00 |
Z-Brackets & Leading Edge Light Cut Outs |
"I had high hopes for this weekend & as usual, I only completed a fraction of the amount I had intended. When will I learn not to set weekend work goals? I kept getting distracted by Non-Plane related work. Kim Had a baby shower on Saturday... We pulled out the Christmas decor & had a blast organizing / ""nesting"" in Addison's room :-). Of course, I got sidetracked by this learning (Leap Frog) stuffed animal thing that I had to hook up to my computer to program / teach it stuff like the baby's name etc. Priming / Prep work pushed off till next weekend. Man, do I have a ton of parts to prime... All I did was this weekend was. - Finished drilling the right tank reiniforcement strip. - Center drill the fuel tank Z-brackets. Offset the bolt holes on the inboard most bracket by 1/16, (away from the bracket web) to allow the use of a socket wrench, should I ever need to remove the tank in the future. (fingers crossed). - Match drilled both leading edge assemblies. - Cut the Landing light cut-outs in the leading edge for the DuckWorksAv.com landing light brackets & drilled the respective ribs." |
