9-27-2012 |
2.00 |
Rear Spar |
"Thanks Van's for not including DWG 38 with the wing kit & sending me on a wild goose chase to verify measurments in the preview plans!!!!!! -Cut inboard rear spar doublers per DWG 38 after verifying the dimensions with Peter D. Who has a current DWG 38 since he is working on the finishing kit. -Match drilled outboard doublers using the spar as a guide. - Marked & rough cut outboard doublers for aileron push rod pass-through. -Deburred all doublers." |
