2-15-2012 |
0.00 |
My Priming / Prep Theory |
After much research & deliberation , I've settled upon my priming / prep process. I know there is an ongoing, never ending debate on aircraft corrosion protect and internal priming. Blah, Blah, Blah. I've decided to prime the whole internal surface of my RV. I am going to be taking a 21st century approach to the subject and avoiding toxic chemical as much as possible. The Priming / Prep process that I'm plan on: - Deburr outer edges of parts prior to fitting & match drilling. - Deburr inter edges & holes prior to dimpling. - Spray part with PreKote & scuff part with maroon scotch-brite pad let it set for 2-3 minutes. - Spray part with PreKote a second time. - Rinse part with water & let it air dry. - Spray epoxy primer. I'm using AKZO" |
