1-6-2008 |
0.00 |
Christmas Bucket - Drilling the fuel cap hole |
I measured a bunch of times on this cut. All the work I put in to getting the leading edge in place could be wasted with one bad measurement. I did it exactly the way Zenith suggested. It worked well. One thing that may present a problem is the angle of the threaded hole for the fuel filler. I believe the top of the tank warped a bit when it was welded. By packing cork on top of the tank seemed to pull the filler flange into position. I'll call Zenith tomorrow for their suggestion. |
