Date:    9-19-2015
Number of Hours:    2.00
Brief Description:    UAT Cable Ground Point
The UAT requires sheilded cable for six of the connections. The rub is that the shield ground pigtails can only be 4" long (per manufacturer). To keep the pigtails that short, I had to remove the UAT mount that I previously completed and install nutplate that I can run a screw into so that I can ground the shield there.
