Date:    2-3-2008
Number of Hours:    1.50
Brief Description:    Finished Aileron Trim Linkages
Not much to look at, really. Just a couple of .040" diameter wires that link the aileron trim servo arm to the springs that connect in turn to the bottoms of the control sticks. In the pic, I show the permanent wire (my finget is touching it) and the temporary one that I used to get the length right.
I installed the servo and actuator arm to make sure the permanent linkages were the right lenghth. Everything looks good and the sticks are parallel and equidistant from the center bulkheads. I'll take it all back out to work on the stick wiring and relay decks, but when it goes back in it'll be done.
