Worked on the centering springs today. I temporarily installed the position indicator LED and the actuator switch so that it was easier to control the servo and also so that I knew where the center location was for the trim system. I could have measured the servo arm, but that would have been a pain. Also, I wanted the sticks to center under the balance of the springs when the indicator showed centered as well. Got it pretty well setup today. Will install the connecting links permanently tomorrow.
