Date:    2-1-2008
Number of Hours:    0.50
Brief Description:    Center Tunnel Line Supports
Little job--made a couple foam supports to keep the brake and fuel lines from rubbing on the floor skin. This center channel is maybe 3/4 in high and will have the brake, fuel, and electrical wire running from the fuselage to the fron of the plane. It'll be under carpeting when everything is finished.
