Date:    12-2-2006
Number of Hours:    4.00
Brief Description:    Fuel Tank Cover Plates
Fabricated the fuel line anti-rotation brackets.
Once those were done and match-drilled to the cover, I prepped the inside cover for pro-sealing. I masked off the area around the fuel sender nutplates and the area under the bracket. I installed the bracket and the fuel line into the cover plates. Set it all aside to cure.
Later the fuel line and the senders...
