3-31-2007 |
2.00 |
VS Rear Spar and Rudder Install |
Pic1 shows the lower VS rear spar after I drilled the pilot holes and one of the holes to full size. Once those were done, I was pretty much finished with the vert stab. Itook Pic2 from behind the aircraft to show the whole assembly (minus the rudder at this point). Pic 3 shows the VS installed and the rudder pinned into place. Tomorrow I'll adjust the hinge bearings and install the rudder stops. |
