11-15-2006 |
2.00 |
Rudder Tip Fairings |
Well so much for my "subsystems approach." Doesn't work sogreat when no one is around to help me lift the wing onto the workbench. Plus, I'm out of parts for electrical work on the left wing. :-/ So, fiberglass work on the tail. I fitted the vertical stabilizer tip fairing and cleco'd it into place. Made a rough cut to get the gap to open uo so that I could install the rudder fairing. Took a good bit of trimming on the rudder fairing to get it to fit, but now have it fitted. Needs some more trimming and the aft holes to be drilled and cleco'd. |
