Date:    6-26-2006
Number of Hours:    3.00
Brief Description:    Trim Tab Assembly
Match-drilled, deburred, and dimpled trim tab skin, spar, and trim control horn. Machine countersunk the top surface of the spar.
Back-riveted spar to bottom of skin.
Completed trailing-edge bend.
Fabricated bending blocks and bent tabs on ends of skin. Match-drilled, deburred, dimpled and blind-riveted tabs.
