Date:    6-15-2006
Number of Hours:    4.50
Brief Description:    Left Elevator Prep
Clecoed skin to structure and then match drilled elevator control horn to spar/rib.
Match drilled skin to structure.
Machine-countersunk the top edge of the trim tab spar and match drilled the trib tab hinge to the spar. Machine countersunk the holes attaching the trim tab spar to the root spar.
