7-10-2007 |
3.00 |
Master and Starter Relay Mounts |
Installed the starter and master relays onto the firewall today. Yeah! Nice to get working on the engine compartment finally. Needed to fabricate a little doubler for the relays and rivet it to the firewall. I also drilled out some existing rivets and installed nutplates. The starter servo is installed upside-down so that when I'm doing acro in this little beast, the starter motor doesn't engage and munch off some flywheel teeth. ;-) |
