Date:    10-10-2015
Number of Hours:    5.00
Brief Description:    Fuel Plumbing
Decided to install the filter, boost pump, and flow meter in the center tunnel under the cockpit floor. To achieve the required straight pipe length upstream of the flow meter, I opted to loop the fuel line aft and then forward again into the flow meter. Still have to fabricate the mountings.
