Date:    3-19-2009
Number of Hours:    3.00
Brief Description:    Fitting axles to spring gear
Fitting axles to spring gear. Very strong piece of aluminium! Weighs 21 Kilos and is 3/4 thick. Had to stand gear up and use my drill press to drill holes after marking with a transfer punch( Thanks to my son Mitchell). Fortunately came out spot on this side. Shaping square edge to axle curvature, and will need a notch cut out for brake calipher mounting bracket.
