Date:    12-18-2008
Number of Hours:    10.00
Brief Description:    Designing Panel Components
Designed Panel components and decided on avionics. Will be using an MGL Enigma full glass panel for all flight and engine monitoring, including GPS and mapping software. The Enigma will also control Trio Avionics auto pilot servos, for 2-axis control. A back-up Garmin GPSMAP196 is also fitted, using an Airgizmo mount. Electrics are catered for with an Exp Bus DC Load centre by Control vision, with a matching indicator module. Ray Allen LED trim indicators, MGL V10 radio and Microair transponder and a compass finish the panel. I fabricated and fitted a map box from Vans on the passenger side.
