1-6-2016 |
2.75 |
Oil Tank, Coolant Bottle, and Engine Prep |
Worked on the Oil Tank & Coolant Recovery Bottle installation. Attempted to install the Radiator Mount Angles, but ran into an issue. Called out bolts (AN4-23A) are too short, require AN4-26As, which I do not have in stock. Also started with the Rotax 912 Engine Prep: - Swapped positions of the Oil Plug and Oil Return Line - Reoriented the Water Pump Inlet casting - Saftied the gearbox Chip Detector - Reversed the Trottle return springs - Removed & Replaced the Throttle Brackets - Rerouted the Fuel Supply line |
