10-1-2015 |
0.75 |
Throttle & Elevator Push Tube |
Section 2.6/4 Throttle Brake Assembly: Continued with this install until I realized I was missing a bolt: AN3-15 Another parts hold. Section 7.3/Pg 2: Elevator Push Tube: Started the fabrication/prep of the Main Push Tube. Await final assembly just prior to setting the fuselage into the hull |
