Date:    5-2-2008
Number of Hours:    5.50
Brief Description:    Horizontal Stabilizer Front and Rear Spars
I began by clecoing together the front and rear spar halves along with their respective doublers, then I matched drilled the holes through the doublers and spars. I fabricated the attach angles by laying them out on the raw stock supplied in the kit and cut them out on my bandsaw. I layed out the rivet holes and clecoed them into place on the spars. I then drilled the remaining holes into the spars and doublers which will be used to rivet these brackets in place. I continued by clecoing and match drilling the elevator hinge brackets on the rear spar.
