Date:    6-8-2008
Number of Hours:    3.80
Brief Description:    Rivet front spar and ribs to skin
I riveted the front spar and ribs together and clecoed it into the skin. I then riveted the assembly to the skin, followed by the rear spar. The VS is done! This is childs play compared to the HS, now I see why some recommend that it be the first assembly you do. (although I managed to screw it up)
Now on to the elevators.
