12-19-2009 |
1.00 |
Dimpled LH Horiz Stabiliser Skin |
Completed dimpling the left horizontal stabliser skin using the DRDT-2 tool, and also used the pop-rivet dimple die tool for the final holes at the tip of the central nose rib. Unlike the earlier picture, the skin was dimpled with the protective blue plastic removed to ensure taht the dies contacted the skin and hence the dimple dimensions would be correct. |
