Date:    12-6-2014
Number of Hours:    0.00
Brief Description:    Avery Tools delivery
At this stage of the build, there are a few additional tools required. One is a specialist tap for the tie down bracket in each wing, and there's also a non-standard (for the toolkit I have) drill size (3/16") required for the bolts that attach the brackets to the wing.
I also took the opportunity to anticipate the future need for a perspex scraper (equivalent of deburring perspex), and I also decided to treat myself to a pneumatic tool that places and removes cleco, given the numerous clecos that will shortly be requirted in the wing build. That should help reduce the potential for RSI with the pliers!
Finally, I needed a replacement band saw blade and at the same time ordered a pneumatic die grinder.
