Date:    1-1-2012
Number of Hours:    2.00
Brief Description:    RH elevator - skeleton
The skeleton needs the flanges to be bent and fluted to ensure that they are at right angles to the webs, and then the whole lot is match-drilled together. This is fairly straightforward, the main difference to what has gone before on other parts is the honking great powder-coated steel elevator horn.
