4-14-2010 |
2.00 |
Sprayed primer on LH Horizontal stab |
Disassembled left hand side of horizontal stabiliser. Degreased and prepared for spraying, and then sprayed skeleton components. (240 ml of primer mix was sufficient.) But... The primer looks horrible. It hasn't adhered in many places, almost as if tere was a contaminent on the metal. I *thought* I'd degreased properly, and am sure that the metal was neither too hot or too cold. The primer mix ratios are correct, so I'm not at all sure what I've done wrong. One thing's for sure, though; this will NOT do. :-( |
