Date:    6-6-2010
Number of Hours:    3.00
Brief Description:    HS ribs
Skipped priming session of HS front spar due to weather. Began rib work by removing excess parts of HS 1004 ribs. Deburred 2 ribs with 2 to go.
(Decided to replace the "just replaced" DeWalt compressor! Realized that the 15 gallon DeWalt compressor was missed labeled as an "oiled compressor" when in fact it is oil free. This explains the loud motor! In addition, when running teh die and angle grinder, the compressor has to run continously to try and keep up. I decided that I'll bring it back and for an even exchange (same price), replace it with a Husky 30 gallon, oiled compressor.
The exchange was made today, and sure enough the new compressor is quieter, has double the volume, and should provide the same service with less cycling.
