3-19-2010 |
7.00 |
Construction begins! |
Today marked the first day of construction. Assembly of the rear spar caps to rear spar took place and the learning process began. Band saws do not make very straight cuts freehand as the blade tends to wander....lesson learned. Squeezing clecos for 7 hrs can blister the hands...even with gloves! The rubber grip on the manual squeezer slips (garbage). Oiler adjusted. Whew. Long day...but WOW...it's on! |
