10-13-2018 |
1.00 |
Lift reserve and USB port |
Installed lift reserve indicator (upper center panel) and USB port (lower left panel). The lift reseve is a magnehelic gauge. When installed in the plane, I'll need to perform in flight tests to determine the actual color arcs for stall ranges, etc. Don't know if I'll need a USB port, but rather install one now then find out in need one later. I'm sure I'll be glad I did. |
